Ir para o conteúdo principal
Garmin Dash Cam 20 Camera Lens Replacement
O que você precisa
  1. Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: passo 1, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: passo 1, imagem 2 %32
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Camera Lens Replacement: passo 2, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 2, imagem 2 %32
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Camera Lens Replacement: passo 3, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 3, imagem 2 %32
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Camera Lens Replacement: passo 4, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 4, imagem 2 %32
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Camera Lens Replacement: passo 5, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 5, imagem 2 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 5, imagem 3 %32
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Camera Lens Replacement: passo 6, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 6, imagem 2 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 6, imagem 3 %32
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: passo 7, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: passo 7, imagem 2 %32
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
  8. Garmin Dash Cam 20 Camera Lens Replacement: passo 8, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 8, imagem 2 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 8, imagem 3 %32
    • Remove the metal case off of the motherboard.
  9. Garmin Dash Cam 20 Camera Lens Replacement: passo 9, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 9, imagem 2 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 9, imagem 3 %32
    • Remove the battery connection.
  10. Garmin Dash Cam 20 Camera Lens Replacement: passo 10, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 10, imagem 2 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 10, imagem 3 %32
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
  11. Garmin Dash Cam 20 Camera Lens Replacement: passo 11, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 11, imagem 2 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 11, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the connector on the top right of the motherboard.
  12. Garmin Dash Cam 20 Camera Lens Replacement: passo 12, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 12, imagem 2 %32 Garmin Dash Cam 20 Camera Lens Replacement: passo 12, imagem 3 %32
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
  13. Garmin Dash Cam 20 Camera Lens Replacement: passo 13, imagem 1 %32
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
  14. Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: passo 14, imagem 1 %32 Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: passo 14, imagem 2 %32
    • Use the Torx T5 screwdriver to remove the two 5mm screws.
    • These screws hold the camera in place. Therefore, the lens will fall into the bottom case.
  15. Garmin Dash Cam 20 Camera Lens Replacement: passo 15, imagem 1 %32
    • The camera lens is now detached.
Conclusão
Jesse Hillman
Membro desde: 10/04/16
757 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 2-1, Cagle Fall 2016 Membro de USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 20
Ao todo: 1,070
