Ir para o conteúdo principal
Gardena EasyCut 9823 disassembly of lower part
O que você precisa
  1. Gardena EasyCut 9823 disassembly of lower part, Gardena EasyCut 9823 disassembly of lower part: passo 1, imagem 1 %32
    • Unscrew the three visible screws, surrounded in red in picture.
  2. Gardena EasyCut 9823 disassembly of lower part: passo 2, imagem 1 %32
    • Remove the two black covers. Frankly, there is no click system.
  3. Gardena EasyCut 9823 disassembly of lower part: passo 3, imagem 1 %32
    • Remove black protection against grass. Do that by rotating it. Rotation is blocked at two places that you can press with a thin screwdriver.
  4. Gardena EasyCut 9823 disassembly of lower part: passo 4, imagem 1 %32 Gardena EasyCut 9823 disassembly of lower part: passo 4, imagem 2 %32 Gardena EasyCut 9823 disassembly of lower part: passo 4, imagem 3 %32
    • Remove the 6 screws now visible in the blue part. Open it in two parts.
  5. Gardena EasyCut 9823 disassembly of lower part: passo 5, imagem 1 %32
    • Pull out white block and engine. Then split white block in two by pulling at the arrow place on provided picture.
  6. Gardena EasyCut 9823 disassembly of lower part: passo 6, imagem 1 %32
    • Clean, fix and re-protect damaged connector.
Conclusão
In order to reassemble your device, please follow instructions in reverse order.
3 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Bossard Nicolas
Membro desde: 09/21/18
1.221 Reputação
Autoria de 6 guias
7 comentários
Thanks a lot! My trimmer had the exact same problem.
trrttsch - Responder
Das gleiche Problem bei 2 Trimmern. Danke, die Anleitung hat sehr geholfen!
Martin Kammerhofer - Responder
Ich hatte das gleiche Problem: ein Draht abgebrochen.
Dannk dieser professionellen Anleitung funktioniert der Rasentrimmer wieder. Ohne diese hätte ich es nicht geschafft, den Grasfangteller zu demontieren
Manfred Schierhuber - Responder
Wo bekommt man einen neuen Motor her
Ulli Leistner - Responder
Da müssen Sie sich wohl an den Hersteller wenden!
Comentar
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 33
Últimos 30 dias: 113
Ao todo: 10,515
