Ir para o conteúdo principal
GameStop GS3 GameCube Controller Disassembly
O que você precisa
  1. GameStop GS3 GameCube Controller Disassembly, Remove four screws on the back of the unit: passo 1, imagem 1 %32 GameStop GS3 GameCube Controller Disassembly, Remove four screws on the back of the unit: passo 1, imagem 2 %32
    • Turn the controller over so the back is facing upwards.
    Pergunte ao FixBot
  2. GameStop GS3 GameCube Controller Disassembly: passo 2, imagem 1 %32 GameStop GS3 GameCube Controller Disassembly: passo 2, imagem 2 %32 GameStop GS3 GameCube Controller Disassembly: passo 2, imagem 3 %32
    • Carefully pry open the controller. Ensure that the rumble assembly stays intact.
    Pergunte ao FixBot
  3. GameStop GS3 GameCube Controller Disassembly: passo 3, imagem 1 %32 GameStop GS3 GameCube Controller Disassembly: passo 3, imagem 2 %32
    • Locate the two black screws attached to the rumble assembly. Remove them and separate the motor from the back casing.
    Pergunte ao FixBot
  4. GameStop GS3 GameCube Controller Disassembly: passo 4, imagem 1 %32 GameStop GS3 GameCube Controller Disassembly: passo 4, imagem 2 %32 GameStop GS3 GameCube Controller Disassembly: passo 4, imagem 3 %32
    • Locate the green pcb on the main assembly. Remove the silver screw on the green pcb to separate it from the controller casing.
    Pergunte ao FixBot
  5. GameStop GS3 GameCube Controller Disassembly: passo 5, imagem 1 %32 GameStop GS3 GameCube Controller Disassembly: passo 5, imagem 2 %32
    • Locate the two silver screws on the brown pcb. Remove them and carefully pry both pcbs off of the controller casing. Ensure that the buttons on the controller casing remain in place.
    Pergunte ao FixBot
  6. GameStop GS3 GameCube Controller Disassembly: passo 6, imagem 1 %32 GameStop GS3 GameCube Controller Disassembly: passo 6, imagem 2 %32
    • Firmly pry the plastic part of the problematic joystick off of the pcb. Take care to ensure that the pcb remains intact.
    Pergunte ao FixBot
  7. GameStop GS3 GameCube Controller Disassembly: passo 7, imagem 1 %32
    • Examine the joystick module on the pcb. Stick drift is a common problem and is usually caused by dirt and debris inside the metal casing. Use rubbing alcohol and a tissue to clean the affected area.
    Pergunte ao FixBot
Conclusão
Brandon
Membro desde: 11/18/19
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 565
