Introdução
If your joystick has broken over time, this guide will help you replace these parts. This repair can take anywhere from 4 to 5 minutes and only requires a Phillips #1 screwdriver and the iFixit opening tool. A good replacement for this device is the Dual Shock 4 joystick.
O que você precisa
Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
Uma outra pessoa concluiu este guia.
3 comentários
I bought ps4 joysticks for the repair, but ps4 joysticks seems larger so it's stuck
PlayStation4 stick is not compatible with GameSir T4 Pro. The stick for the Nintendo Switch PRO controller does not interfere, but this also requires processing for installation.
It appears that you will need to remove the light diffuser(white tubular plastic sleeve) from the case to make the parts fit.
NAKIRI -
