Ir para o conteúdo principal
GameSir T4 Pro Directional Pad Replacement
O que você precisa
  1. GameSir T4 Pro Directional Pad Replacement, Battery: passo 1, imagem 1 %32
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Directional Pad Replacement: passo 2, imagem 1 %32
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Directional Pad Replacement: passo 3, imagem 1 %32
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Directional Pad Replacement: passo 4, imagem 1 %32
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Directional Pad Replacement, Directional Pad: passo 5, imagem 1 %32 GameSir T4 Pro Directional Pad Replacement, Directional Pad: passo 5, imagem 2 %32
    • To get to the directional pad (d-pad), remove the three 5mm screws on the motherboard.
  6. GameSir T4 Pro Directional Pad Replacement: passo 6, imagem 1 %32
    • Disconnect all white connectors from the motherboard.
  7. GameSir T4 Pro Directional Pad Replacement: passo 7, imagem 1 %32
    • Carefully pull the motherboard away to reveal the front panel.
  8. GameSir T4 Pro Directional Pad Replacement: passo 8, imagem 1 %32
    • Remove the d-pad from the front panel.
  9. GameSir T4 Pro Directional Pad Replacement: passo 9, imagem 1 %32
    • Place your new d-pad in place.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 33
Duração total: 696
