Introdução
This guide will help you repair the directional pad on your GameSir Pro T4.
Directional pads need replacement after wear and tear over time or if it somehow cracks.
O que você precisa
Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
To get to the directional pad (d-pad), remove the three 5mm screws on the motherboard.
