Ir para o conteúdo principal
GameSir T4 Pro Charging Port Replacement
O que você precisa
  1. GameSir T4 Pro Charging Port Replacement, Battery: passo 1, imagem 1 %32
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Charging Port Replacement: passo 2, imagem 1 %32
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Charging Port Replacement: passo 3, imagem 1 %32
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Charging Port Replacement: passo 4, imagem 1 %32
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Charging Port Replacement, Charging Port: passo 5, imagem 1 %32 GameSir T4 Pro Charging Port Replacement, Charging Port: passo 5, imagem 2 %32
    • Use the needle nose pliers to remove the plastic connection from the motherboard.
    • You may hold the wires for stability, but do not tug on the wires.
  6. GameSir T4 Pro Charging Port Replacement: passo 6, imagem 1 %32 GameSir T4 Pro Charging Port Replacement: passo 6, imagem 2 %32
    • Remove the two 5mm screws on the charging port and take out the old charging port.
  7. GameSir T4 Pro Charging Port Replacement: passo 7, imagem 1 %32 GameSir T4 Pro Charging Port Replacement: passo 7, imagem 2 %32
    • Put your new compatible charging port in place.
    • Make sure to screw in the 5mm screws into your new charing port
Conclusão
Um comentário
Where i can buy the charging port? Some buttons isnt working so when i was trying to solve the problem with contact cleaner i ended up breaking the soldered connection
Eron Araújo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 847
