Ir para o conteúdo principal
GameSir T4 Pro Battery Replacement
O que você precisa
  1. GameSir T4 Pro Battery Replacement, Battery: passo 1, imagem 1 %32
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Battery Replacement: passo 2, imagem 1 %32
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Battery Replacement: passo 3, imagem 1 %32
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Battery Replacement: passo 4, imagem 1 %32
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
Battery Model is pl502450 600mah
3.7v
Eugene Eugenio - Responder
Where can I buy this battery? Do You have a link to it?
Roberto Barros -
Roberto Barros - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 95
Duração total: 1,743
