Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
Remove the six Triwing screws from the back of the device.
Gently separate the device's front casing from the back casing after you remove the screws.
Slide the front side of the casing down to expose the ribbon cable connector.
Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
Separate the front and back casings.
Remove the 10 Phillips #00 screws from the motherboard.
Use a plastic opening tool to gently lift the motherboard up and remove it from the front plastic case.
Desolder the two wires connecting the speaker to the motherboard.
Remove the speaker.
16 outras pessoas executaram este guia.
2 comentários
This is just a guide to remove the speaker not replacing it so change the title as it is misleading as people that following this will want know how to replace not remove only
As stated in the conclusion, you simply follow the steps in reverse to install your replacement speaker.
