Ir para o conteúdo principal
Game Boy Pocket Front Housing Replacement
O que você precisa
  1. Game Boy Pocket Front Housing Replacement, Remove the external screws: passo 1, imagem 1 %32 Game Boy Pocket Front Housing Replacement, Remove the external screws: passo 1, imagem 2 %32 Game Boy Pocket Front Housing Replacement, Remove the external screws: passo 1, imagem 3 %32
    • Place the Game Boy Pocket face-down on a clean, flat surface. Remove the battery compartment cover, along with any batteries inside.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside of the battery compartment.
  2. Game Boy Pocket Front Housing Replacement, Open the device: passo 2, imagem 1 %32 Game Boy Pocket Front Housing Replacement, Open the device: passo 2, imagem 2 %32 Game Boy Pocket Front Housing Replacement, Open the device: passo 2, imagem 3 %32
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device later.
  3. Game Boy Pocket Front Housing Replacement, Remove the motherboard screws: passo 3, imagem 1 %32
    • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
  4. Game Boy Pocket Front Housing Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 1 %32 Game Boy Pocket Front Housing Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 2 %32 Game Boy Pocket Front Housing Replacement, Remove the clip securing the ribbon cable: passo 4, imagem 3 %32
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Front Housing Replacement, Dislodge the ribbon cable: passo 5, imagem 1 %32 Game Boy Pocket Front Housing Replacement, Dislodge the ribbon cable: passo 5, imagem 2 %32
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Front Housing Replacement, Remove the motherboard: passo 6, imagem 1 %32 Game Boy Pocket Front Housing Replacement, Remove the motherboard: passo 6, imagem 2 %32 Game Boy Pocket Front Housing Replacement, Remove the motherboard: passo 6, imagem 3 %32
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket Front Housing Replacement, Remove the buttons: passo 7, imagem 1 %32 Game Boy Pocket Front Housing Replacement, Remove the buttons: passo 7, imagem 2 %32 Game Boy Pocket Front Housing Replacement, Remove the buttons: passo 7, imagem 3 %32
    • Use your fingers to remove the three silicone button covers
    • Use a plastic opening tool to remove the buttons.
  8. Game Boy Pocket Front Housing Replacement, Remove the LCD screen: passo 8, imagem 1 %32 Game Boy Pocket Front Housing Replacement, Remove the LCD screen: passo 8, imagem 2 %32 Game Boy Pocket Front Housing Replacement, Remove the LCD screen: passo 8, imagem 3 %32
    • Use a plastic opening tool to lift the LCD screen away from the front cover.
    • Use your fingers to remove the LCD screen.
    • Set the LCD screen aside. You will need it to reassemble the device.
  9. Game Boy Pocket Front Housing Replacement, Replace the front housing: passo 9, imagem 1 %32
    • Replace the front housing, following each step in reverse order.
Conclusão
Adriana Rahrig
Membro desde: 10/07/14
1.523 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-1, Leahy Fall 2014 Membro de USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 30
Duração total: 4,095
