Ir para o conteúdo principal
Game Boy Pocket Buttons Replacement
O que você precisa
  1. Game Boy Pocket Buttons Replacement, Buttons: passo 1, imagem 1 %32 Game Boy Pocket Buttons Replacement, Buttons: passo 1, imagem 2 %32 Game Boy Pocket Buttons Replacement, Buttons: passo 1, imagem 3 %32
    • Place the Game Boy Pocket face-down on a clean, flat surface.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
    • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
  2. Game Boy Pocket Buttons Replacement: passo 2, imagem 1 %32 Game Boy Pocket Buttons Replacement: passo 2, imagem 2 %32 Game Boy Pocket Buttons Replacement: passo 2, imagem 3 %32
    • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
    • Set the back cover aside. You will need it to reassemble the device.
  3. Game Boy Pocket Buttons Replacement: passo 3, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the three screws from the motherboard.
  4. Game Boy Pocket Buttons Replacement: passo 4, imagem 1 %32 Game Boy Pocket Buttons Replacement: passo 4, imagem 2 %32 Game Boy Pocket Buttons Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
    • Make sure you apply pressure on both sides of the clip to loosen it.
  5. Game Boy Pocket Buttons Replacement: passo 5, imagem 1 %32 Game Boy Pocket Buttons Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to dislodge the ribbon cable.
    • Be gentle to prevent tearing the ribbon.
  6. Game Boy Pocket Buttons Replacement: passo 6, imagem 1 %32 Game Boy Pocket Buttons Replacement: passo 6, imagem 2 %32 Game Boy Pocket Buttons Replacement: passo 6, imagem 3 %32
    • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
    • Set the motherboard aside. You will need it to reassemble the device.
  7. Game Boy Pocket Buttons Replacement: passo 7, imagem 1 %32 Game Boy Pocket Buttons Replacement: passo 7, imagem 2 %32 Game Boy Pocket Buttons Replacement: passo 7, imagem 3 %32
    • Use your fingers to remove the three silicone button covers.
    • Use a plastic opening tool to remove the buttons.
Conclusão
3 outras pessoas executaram este guia.
Adriana Rahrig
Membro desde: 10/07/14
1.637 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-1, Leahy Fall 2014 Membro de USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Membros
Autoria de 19 guias
1Comentário do guia
where can you just buy the a and b buttons (if possible)
Eian Anderson - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 5,426
