Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
Remove the six Triwing screws from the back of the device.
Gently separate the device's front casing from the back casing after you remove the screws.
Slide the front side of the casing down to expose the ribbon cable connector.
Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
Separate the front and back casings.
13 outras pessoas executaram este guia.
2 comentários
U need a tri-wing screwdriver not a Philips #00
