Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide, we'll show you how to change the LCD Screen.
O que você precisa
Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
Once the screw has been loosened, lift the cover off the back of the device.
Locate the two circular holes on the side of the Game Boy nearest to the directional pad.
Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch.
The LCD screen is connected to the motherboard by two ribbon cables.
Use a plastic spudger to disconnect the LCD's ZIF connector.
7 outras pessoas executaram este guia.
