Ir para o conteúdo principal
Game Boy Color Screen Cover Replacement
O que você precisa
  1. Game Boy Color Screen Cover Replacement, Battery: passo 1, imagem 1 %32 Game Boy Color Screen Cover Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Screen Cover Replacement: passo 2, imagem 1 %32
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Screen Cover Replacement, Screen Cover: passo 3, imagem 1 %32
    • Carefully slide a razor blade under one of the corners of the screen cover.
  4. Game Boy Color Screen Cover Replacement: passo 4, imagem 1 %32
    • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Continue gently pulling up on the cover until it is fully removed.
Conclusão
24 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 19-47, Regan Winter 2013 Membro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
Membros da 4
Autoria de 61 guias
4 comentários
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - Responder
You only need step 7 and 8.
h027299c - Responder
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - Responder
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 43
Últimos 30 dias: 176
Duração total: 22,628
