Ir para o conteúdo principal
Game Boy Color LCD Ribbon Cable Replacement
O que você precisa
  1. Game Boy Color LCD Ribbon Cable Replacement, Battery: passo 1, imagem 1 %32 Game Boy Color LCD Ribbon Cable Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color LCD Ribbon Cable Replacement: passo 2, imagem 1 %32
    • Remove the batteries from the battery compartment.
  3. Game Boy Color LCD Ribbon Cable Replacement, Back Housing: passo 3, imagem 1 %32
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    I did this with a Y0 bit. It works if you are careful. I wouldn't recommend it on other consoles but for this tiny thing, it works.
    phnome - Responder
    The guide says a Y0 is needed. Is it a Y1 or Y0?
    Trav - Responder
  4. Game Boy Color LCD Ribbon Cable Replacement: passo 4, imagem 1 %32 Game Boy Color LCD Ribbon Cable Replacement: passo 4, imagem 2 %32
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color LCD Ribbon Cable Replacement, LCD Ribbon Cable: passo 5, imagem 1 %32
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color LCD Ribbon Cable Replacement: passo 6, imagem 1 %32
    • Gently remove the ribbon cable from the port
Conclusão
11 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 19-47, Regan Winter 2013 Membro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
Membros da 4
Autoria de 56 guias
Um comentário
How many pins are in the ribbon?
jakebrown199 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 80
Duração total: 8,316
