Ir para o conteúdo principal
Game Boy Color Front Housing Replacement
O que você precisa
  1. Game Boy Color Front Housing Replacement, Battery: passo 1, imagem 1 %32 Game Boy Color Front Housing Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Front Housing Replacement: passo 2, imagem 1 %32
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Front Housing Replacement, Back Housing: passo 3, imagem 1 %32
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Front Housing Replacement: passo 4, imagem 1 %32 Game Boy Color Front Housing Replacement: passo 4, imagem 2 %32
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Front Housing Replacement, LCD Ribbon Cable: passo 5, imagem 1 %32 Game Boy Color Front Housing Replacement, LCD Ribbon Cable: passo 5, imagem 2 %32 Game Boy Color Front Housing Replacement, LCD Ribbon Cable: passo 5, imagem 3 %32
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Front Housing Replacement: passo 6, imagem 1 %32 Game Boy Color Front Housing Replacement: passo 6, imagem 2 %32
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Front Housing Replacement, Motherboard: passo 7, imagem 1 %32 Game Boy Color Front Housing Replacement, Motherboard: passo 7, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  8. Game Boy Color Front Housing Replacement: passo 8, imagem 1 %32
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Front Housing Replacement, Buttons: passo 9, imagem 1 %32
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Front Housing Replacement: passo 10, imagem 1 %32
    • Remove the original buttons from the housing.
  11. Game Boy Color Front Housing Replacement, LCD Display: passo 11, imagem 1 %32 Game Boy Color Front Housing Replacement, LCD Display: passo 11, imagem 2 %32
    • Gently pry and lift the LCD Display from the front panel.
    • Twisting the front casing may help gain more leverage.
Conclusão
22 outras pessoas executaram este guia.
Angela Yoeurng
Membro desde: 01/18/13
1.967 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 19-47, Regan Winter 2013 Membro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Membros
Autoria de 61 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 28
Últimos 30 dias: 99
Ao todo: 12,849
