Ir para o conteúdo principal
Game Boy Color Buttons Replacement
O que você precisa
  1. Game Boy Color Buttons Replacement, Battery: passo 1, imagem 1 %32 Game Boy Color Buttons Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    Pergunte ao FixBot
  2. Game Boy Color Buttons Replacement: passo 2, imagem 1 %32
    • Remove the batteries from the battery compartment.
    Pergunte ao FixBot
  3. Game Boy Color Buttons Replacement, Back Housing: passo 3, imagem 1 %32
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    Pergunte ao FixBot
  4. Game Boy Color Buttons Replacement: passo 4, imagem 1 %32 Game Boy Color Buttons Replacement: passo 4, imagem 2 %32
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
    Pergunte ao FixBot
  5. Game Boy Color Buttons Replacement, LCD Ribbon Cable: passo 5, imagem 1 %32 Game Boy Color Buttons Replacement, LCD Ribbon Cable: passo 5, imagem 2 %32 Game Boy Color Buttons Replacement, LCD Ribbon Cable: passo 5, imagem 3 %32
    • Push up on the tabs on either side of the ribbon with a spudger.
    Pergunte ao FixBot
  6. Game Boy Color Buttons Replacement: passo 6, imagem 1 %32 Game Boy Color Buttons Replacement: passo 6, imagem 2 %32
    • Gently remove the ribbon cable from the port
    Pergunte ao FixBot
  7. Game Boy Color Buttons Replacement, Motherboard: passo 7, imagem 1 %32 Game Boy Color Buttons Replacement, Motherboard: passo 7, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    Pergunte ao FixBot
  8. Game Boy Color Buttons Replacement: passo 8, imagem 1 %32
    • Gently lift the motherboard from the front housing.
    Pergunte ao FixBot
  9. Game Boy Color Buttons Replacement, Buttons: passo 9, imagem 1 %32
    • Remove the rubber backing on each button grouping.
    Pergunte ao FixBot
  10. Game Boy Color Buttons Replacement: passo 10, imagem 1 %32
    • Remove the original buttons from the housing.
    Pergunte ao FixBot
Conclusão
28 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 19-47, Regan Winter 2013 Membro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Membros
Autoria de 61 guias
3Comentários do guia
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - Responder Compartilhar
In the tools needed it states Y0 screwdriver, but in step 3 it says Y1 which is not the same. Which one is the correct size?
blogcraft - Responder Compartilhar
I found either Y0 or Y1 works. The important thing is it's a small tri-wing.
Michael Schwern - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 51
Últimos 30 dias: 269
Ao todo: 34,659
