Introdução
How to remove the back housing of the Game Boy Color.
O que você precisa
Locate the battery compartment on the back of the Game Boy Color.
Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
16 outras pessoas executaram este guia.
2 comentários
Can’t seem to figure out how to remove the battery prongs off the back housing :(
If you didn't get it figured out, there is a small metal leg visible from the inside of the housing on the side closest to the edge of the housing. You can press the leg down with a pair of tweezers while pressing the battery prong plate down gently and it should pop free and allow you to push the prong out.
Wesley -
