Ir para o conteúdo principal
Game Boy Color Back Housing Replacement
O que você precisa
  1. Game Boy Color Back Housing Replacement, Battery: passo 1, imagem 1 %32 Game Boy Color Back Housing Replacement, Battery: passo 1, imagem 2 %32
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Back Housing Replacement: passo 2, imagem 1 %32
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Back Housing Replacement, Back Housing: passo 3, imagem 1 %32
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Back Housing Replacement: passo 4, imagem 1 %32 Game Boy Color Back Housing Replacement: passo 4, imagem 2 %32
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
Conclusão
20 outras pessoas executaram este guia.
Angela Yoeurng
Membro desde: 01/18/13
1.950 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 19-47, Regan Winter 2013 Membro de Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Membros
Autoria de 61 guias
2Comentários do guia
Can’t seem to figure out how to remove the battery prongs off the back housing :(
Eddy G - Responder
If you didn't get it figured out, there is a small metal leg visible from the inside of the housing on the side closest to the edge of the housing. You can press the leg down with a pair of tweezers while pressing the battery prong plate down gently and it should pop free and allow you to push the prong out.
Wesley -
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 32
Últimos 30 dias: 111
Ao todo: 10,651
