Ir para o conteúdo principal
Game Boy Advance Shoulder Button and Side Panels Replacement
O que você precisa
  1. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 1 %32 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 2 %32 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 3 %32
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Shoulder Button and Side Panels Replacement, Unscrew the Back Panel: passo 2, imagem 1 %32 Game Boy Advance Shoulder Button and Side Panels Replacement, Unscrew the Back Panel: passo 2, imagem 2 %32
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Back Panel: passo 3, imagem 1 %32
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: passo 4, imagem 1 %32 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: passo 4, imagem 2 %32
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - Responder
Conclusão
4 outras pessoas executaram este guia.
Aldo Corona
Membro desde: 01/25/10
799 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 16-29, Maness Winter 2010 Membro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
Membros da 5
Autoria de 61 guias
Um comentário
i need help th e side pannels loose
Mark - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 54
Duração total: 7,940
