Ir para o conteúdo principal
Game Boy Advance Battery Replacement
  1. Game Boy Advance Battery Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 1 %32 Game Boy Advance Battery Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 2 %32 Game Boy Advance Battery Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 3 %32
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
Conclusão
6 outras pessoas executaram este guia.
Aldo Corona
Membro desde: 01/25/10
814 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 16-29, Maness Winter 2010 Membro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Membros
Autoria de 62 guias
Um comentário
how could you take rust off the battery hinges?
Sinai Garcia - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 49
Últimos 30 dias: 196
Ao todo: 18,249
