Ir para o conteúdo principal
Galaxy Watch Active2 Core Assembly Removal
O que você precisa
  1. Galaxy Watch Active2 Core Assembly Removal, Turn off the watch: passo 1, imagem 1 %32 Galaxy Watch Active2 Core Assembly Removal, Turn off the watch: passo 1, imagem 2 %32
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Galaxy Watch Active2 Core Assembly Removal, Remove the rear screws: passo 2, imagem 1 %32
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Galaxy Watch Active2 Core Assembly Removal, Separate the back cover from the housing: passo 3, imagem 1 %32 Galaxy Watch Active2 Core Assembly Removal, Separate the back cover from the housing: passo 3, imagem 2 %32 Galaxy Watch Active2 Core Assembly Removal, Separate the back cover from the housing: passo 3, imagem 3 %32
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Galaxy Watch Active2 Core Assembly Removal, Disconnect the sensor array: passo 4, imagem 1 %32 Galaxy Watch Active2 Core Assembly Removal, Disconnect the sensor array: passo 4, imagem 2 %32
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Galaxy Watch Active2 Core Assembly Removal, Remove the back cover: passo 5, imagem 1 %32
    • Remove the back cover.
  6. Galaxy Watch Active2 Core Assembly Removal, Disconnect the display and speaker: passo 6, imagem 1 %32 Galaxy Watch Active2 Core Assembly Removal, Disconnect the display and speaker: passo 6, imagem 2 %32 Galaxy Watch Active2 Core Assembly Removal, Disconnect the display and speaker: passo 6, imagem 3 %32
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Galaxy Watch Active2 Core Assembly Removal, Disconnect the barometric sensor, buttons, and mic: passo 7, imagem 1 %32 Galaxy Watch Active2 Core Assembly Removal, Disconnect the barometric sensor, buttons, and mic: passo 7, imagem 2 %32 Galaxy Watch Active2 Core Assembly Removal, Disconnect the barometric sensor, buttons, and mic: passo 7, imagem 3 %32
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Galaxy Watch Active2 Core Assembly Removal, Lift the core assembly: passo 8, imagem 1 %32 Galaxy Watch Active2 Core Assembly Removal, Lift the core assembly: passo 8, imagem 2 %32
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Galaxy Watch Active2 Core Assembly Removal, Remove the core assembly: passo 9, imagem 1 %32 Galaxy Watch Active2 Core Assembly Removal, Remove the core assembly: passo 9, imagem 2 %32 Galaxy Watch Active2 Core Assembly Removal, Remove the core assembly: passo 9, imagem 3 %32
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
Conclusão
7 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
124.338 Reputação
Autoria de 189 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 94
Ao todo: 8,309
