Ir para o conteúdo principal
Galaxy Tab S 10.5 Camera Replacement
O que você precisa
  1. Galaxy Tab S 10.5 Camera Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: passo 1, imagem 1 %32 Galaxy Tab S 10.5 Camera Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: passo 1, imagem 2 %32
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Galaxy Tab S 10.5 Camera Replacement: passo 2, imagem 1 %32
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Galaxy Tab S 10.5 Camera Replacement: passo 3, imagem 1 %32
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Galaxy Tab S 10.5 Camera Replacement, Camera: passo 4, imagem 1 %32 Galaxy Tab S 10.5 Camera Replacement, Camera: passo 4, imagem 2 %32 Galaxy Tab S 10.5 Camera Replacement, Camera: passo 4, imagem 3 %32
    • Use a spudger to disconnect the camera from the motherboard and then remove the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Jordan Soto
Membro desde: 08/26/15
3.276 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 3-2, Eyestone Fall 2015 Membro de USF Tampa, Team 3-2, Eyestone Fall 2015
USFT-EYESTONE-F15S3G2
Membros da 3
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 2,565
