Ir para o conteúdo principal
Galaxy J3 Prime LCD Screen Replacement
O que você precisa
Vídeo de Apresentação
    • Remove the back cover and battery.
    • Heat up the screen to loosen the adhesive.
    • You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
    • Put a spudger between the phone frame and the front display.
    • Remove the plastic bracket that will be visible when you pry up the screen.
    • Gently pull up on the LCD screen adhesive to remove the screen.
    • Remove the screws on the back of the phone frame that are holding the housing of the phone together.
    • Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
    • Be gentle so you don't break anything.
    • Disconnect the metal flex cable from the charging port.
    • Remove the Motherboard from the housing.
Conclusão
9 outras pessoas executaram este guia.
Brian Brown
Membro desde: 09/26/16
393 Reputação
Autoria de 1 guia
3 comentários
great guide, this really helped
anonymous 591 - Responder
thanks for your help, this has really helped
Marvinhenderson4@gmail.com - Responder
Best guide for a J3 out there professional and easy to follow
Keith Pobuta - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 6,967
