Ir para o conteúdo principal
Galaxy A71 FPC Repair
O que você precisa
Vídeo de Apresentação
  1. Galaxy A71 FPC Repair, Connect the charger: passo 1, imagem 1 %32 Galaxy A71 FPC Repair, Connect the charger: passo 1, imagem 2 %32
    • Samsung Galaxy A71 does not charge.
    • Connect the charger and press the phone as per the second image.
  2. Galaxy A71 FPC Repair, Back cover removal: passo 2, imagem 1 %32 Galaxy A71 FPC Repair, Back cover removal: passo 2, imagem 2 %32 Galaxy A71 FPC Repair, Back cover removal: passo 2, imagem 3 %32
    • Warm the device to soften the adhesive.
    • Use plastic tools and isopropyl alcohol to separate the back cover.
  3. Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: passo 3, imagem 1 %32 Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: passo 3, imagem 2 %32 Galaxy A71 FPC Repair, Middle frame removal / SIM Tray removal: passo 3, imagem 3 %32
    • Remove all silver Phillips screws.
    • Remove the SIM Tray.
    • Use a suitable plastic tool to remove the middle frame.
  4. Galaxy A71 FPC Repair: passo 4, imagem 1 %32 Galaxy A71 FPC Repair: passo 4, imagem 2 %32
    • Disconnect the battery.
    • Connect the charger and measure the voltage at the two end pins. It should be ~5V.
    • If not, search for the problem at the charging board or the main flex cable.
  5. Galaxy A71 FPC Repair: passo 5, imagem 1 %32 Galaxy A71 FPC Repair: passo 5, imagem 2 %32
    • Remove the black tape stuck around the connector.
    • Use a soldering iron, flux and tin wire to resolder the first pin of the FPC connector.
    • If the connector is broken, it's better to replace it.
Conclusão
10 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.368 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.464 guias
Um comentário
Good morning. My A71 screen is blinking on and off black screen. What can I do to fix it? Also when I'm attempting to type in any chat I have to press down really hard to get the letters on the screen? As my phone heats up it goes black,if I'm in a room that has AC units it remains on for a longer period of time.
KEMBA LEOUNG TAT - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 71
Últimos 30 dias: 351
Duração total: 10,526
