Introdução
O que você precisa
Remove all screws using your P#1 screwdriver. There are four large screws in the top and bottom, and the six smaller screws on the sides.
Honestly, the toughest part of the replacement are these three clips on each side. I found that prying the top two first makes it a little more easy.
After you get it unclipped, take out the screen assembly, and flip it over on its face.
Looking at the back, you can see the LCD cable, most likely you will have some hot glue on the back covering the cord.
For my replacement my connector was soldered in-place. NOT glued on my model, required a soldering iron for removal.
9 outras pessoas executaram este guia.
19 comentários
if you use a blow dryer or heat gun on the front sticker - get it good and toasty, it comes out easier and in one piece. Also - blow dryer for the screen bezel - not too hot, but enough to loosen up the glue thats holding it down.
Last of all - on my gaems system - the connection to the lcd was both hot glue and solder - I had to use a de-soldering wick to take solder off the sides of the holding bracket.
Thanks for the tutorial - i had no idea how to get started
I'd like to see if I can put a 17" full 1080P HD or even the 19" one.. not sure if this case is the same size as their 19" model..but if it is.. their 19" model is a 720P display as well. I'd like to get an updated full HD display with better viewing angles.. any thoughts?
not a bad idea.. I just picked one of these up today for $20 that has a cracked screen. Wanting to use the case as a GCS for my R/c UAVs. It seems the monitor is no different than a standard 15.5" laptop LCD screen. I have a bunch laying around that I'm going to try and swap the cracked one out with. I have looked at the different cases and I will agree, I believe their cases are all the same dimensions with the exception of the mounting screws (19" screen would have mounting holes further apart than the 15.5") but with a little modification, im sure you could mount one in just fine. I also plan on creating a protective layer between the LCD and other hardware so something like this doesnt happen again when transporting it! I'll let you all know when its done
And if I accidentally break the connectors, is there somewhere I can buy a replacement for that? There was much more glue than I thought and the whole thing is broken now. (I'm having a rough day, if you hadn't guessed).
they must have changed the design. I was going crazy trying to pry off the circle logo. My g155 only needed to remove 6 screws surrounding plastic frame on inside of case
My one doesn't work! The power light comes on and lights up red, but that's it. I hooked up something through the HDMI port but still nothing. Please help!!!!!
Do I need to fix the screen, or do I need to replace it?
Were can I get a replacement screen from?
Hi,
Do any of you know how to do a g190 screen, I would assume its very similar ?
Regards Jason
You can use any 15.5" computer screen as long as it has the same connection ports. I used the Dell XPS LED screen part number B156HW01 and when I broke that one. I used the Dell XPS B156XW02 model.
Are those 1080p screens?
My screen comes on with the logo but won't recognize any hdmi input … is there a fix for this?
I’ve experienced this as well while utilizing my PlayStation 4. I’ve found I need to have the display powered in prior to booting up my gaming system. For what ever reason the machine won’t recognize the display of it doesn’t exist at the time of power up. Please also try a different component such as another HDMI cable or DVD player in order to verify it’s not the display.
I put new screen in my g155 but is to dim to see anyone know how to fix this
I debated about replacing the screen myself or discarding the equipment entirely. Was able to remove the display easily and locate an LG part number off the old display “LP156WH4”. The units main connector was soldered In place. My recommendation is to church your self up with a basic soldering YouTube video. Reason being the joint is flat as to where you cannot suck the solder from the connection. The technique I employed was heating each corner and lightly pulling the connector out. I had no trouble new with the new monitors installation. The connector fit like a champ and I reapplied solder to the connector to keep it in place.
current versions from the last few years doesn’t have hidden screws through the back center round section. It can all be removed from inside the case easily. There are two hidden torx 1.0 screws under two small rubber round inserts at the top middle of the screen bezel on the inside in addition to the 4 each 3.0 allen screws easily seen at the corners.
screen model in ours (3-4 years old) is a 15.6” Chimei innolux N156BGE -L21 Rev.C1. A newer model (1-2 years old) looks identical construction wise
My GAEMS screen is fine, but the whole device got hit by an IR signal and found the tuner inside. It caused the thing to switch from HDMI to over the air antenna. Now I can’t find a way to get HDMI back as the stray IR device signal wasn’t 100% compatible. So I’m stuck with it on channel 5. Help?
