Ir para o conteúdo principal
GMMK-BRN Keyboard Switch Replacement
O que você precisa
  1. GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: passo 1, imagem 1 %32 GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: passo 1, imagem 2 %32
    • Unplug the keyboard from your device.
    • Place the keyboard on a clean workspace, along with the tools required.
  2. GMMK-BRN Keyboard Switch Replacement: passo 2, imagem 1 %32 GMMK-BRN Keyboard Switch Replacement: passo 2, imagem 2 %32 GMMK-BRN Keyboard Switch Replacement: passo 2, imagem 3 %32
    • Use your fingers or a keycap remover and pull directly upward to remove the keycap.
    • It is possible to damage the keycap if not pulled directly upwards.
  3. GMMK-BRN Keyboard Switch Replacement: passo 3, imagem 1 %32 GMMK-BRN Keyboard Switch Replacement: passo 3, imagem 2 %32
    • Use the switch remover to push the tabs in on the opposite sides of the switch.
    • Firmly pull the switch upwards.
    • If the switch is pulled at an angle, there is a risk to damaging the switch.
    • The switch may not come out easily, so more force may be required.
  4. GMMK-BRN Keyboard Switch Replacement: passo 4, imagem 1 %32 GMMK-BRN Keyboard Switch Replacement: passo 4, imagem 2 %32 GMMK-BRN Keyboard Switch Replacement: passo 4, imagem 3 %32
    • Align the pins on the keycap with the ones inside the keyboard.
    • Insert the switch, and press down firmly until a click is heard.
  5. GMMK-BRN Keyboard Switch Replacement: passo 5, imagem 1 %32 GMMK-BRN Keyboard Switch Replacement: passo 5, imagem 2 %32 GMMK-BRN Keyboard Switch Replacement: passo 5, imagem 3 %32
    • Align the cross of the keycap with the cross of the switch.
    • Push the keycap down firmly to reattach.
  6. GMMK-BRN Keyboard Switch Replacement: passo 6, imagem 1 %32 GMMK-BRN Keyboard Switch Replacement: passo 6, imagem 2 %32
    • Plug the keyboard back into your device.
    • Turn you device on and do a test to see if the new switch works.
Conclusão
Kyle Lieu Dang
Membro desde: 01/30/23
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 304
