Ir para o conteúdo principal
GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement
O que você precisa
  1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: passo 1, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: passo 1, imagem 2 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: passo 1, imagem 3 %32
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: passo 2, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: passo 2, imagem 2 %32
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: passo 3, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: passo 3, imagem 2 %32
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, LCD Cover: passo 4, imagem 1 %32
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: passo 5, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: passo 5, imagem 2 %32
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: passo 6, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: passo 6, imagem 2 %32
    • Grip the speaker.
    • Lift the speaker from the holder.
    • Turn the speaker over.
  7. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: passo 7, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: passo 7, imagem 2 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: passo 7, imagem 3 %32
    • The red wire is the + and the tan wire is the -. These wires are connected with solder.
    • Apply the hot soldering iron tip to the speaker connection solder.
    • Pull the speaker away from the wires.
  8. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: passo 8, imagem 1 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: passo 8, imagem 2 %32 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: passo 8, imagem 3 %32
    • Attach a new 65 mm speaker, model #115048352530, with the wire connectors. Match the red wire to the + and the tan wire to the -.
    • Solder the wires to connect. Let the solder cool.
    • Reverse Step 6 to insert the new speaker in holder.
Conclusão
Uma outra pessoa concluiu este guia.
Dominick Giguere
Membro desde: 10/28/14
848 Reputação
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 1,599
