Introdução
In this guide, we will walk you through the steps to change a burned out lightbulb in your GE 30" Electric JCB635DKWW oven. For this replacement, all you will need is a replacement bulb. Having a functioning light bulb in your oven is essential to any baking process as it helps you monitor your dishes, without the disadvantage of opening the oven, taking out your dish, and losing heat in the process.
You will be working inside the oven for the repair. For safety reasons, before beginning this repair, make sure your oven is off and cooled down if it was on recently.
O que você precisa
