Ir para o conteúdo principal
GD Midea FT30-3D Fan Blades Replacement
O que você precisa
  1. GD Midea FT30-3D Fan Blades Replacement, Fan Blades: passo 1, imagem 1 %32 GD Midea FT30-3D Fan Blades Replacement, Fan Blades: passo 1, imagem 2 %32
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  2. GD Midea FT30-3D Fan Blades Replacement: passo 2, imagem 1 %32
    • Pull the front fan guard off.
  3. GD Midea FT30-3D Fan Blades Replacement: passo 3, imagem 1 %32 GD Midea FT30-3D Fan Blades Replacement: passo 3, imagem 2 %32
    • Remove the spinner from the center of the fan blade.
    So how do i take the spinner off the fan
    Martha Meza - Responder
    H how do I take the spinner off the center of a fan I don't know how
  4. GD Midea FT30-3D Fan Blades Replacement: passo 4, imagem 1 %32
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
Conclusão
6 outras pessoas executaram este guia.
Alan Su
Membro desde: 10/03/12
810 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 24-28, Regan Fall 2012 Membro de Cal Poly, Team 24-28, Regan Fall 2012
CPSU-REGAN-F12S24G28
4 Membros
Autoria de 14 guias
Um comentário
Where do you buy the fan blades?
charlie - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Ao todo: 3,342
