Ir para o conteúdo principal
GBC Creative Laminator Gear Replacement
O que você precisa
  1. GBC Creative Laminator Gear Replacement, Gear: passo 1, imagem 1 %32 GBC Creative Laminator Gear Replacement, Gear: passo 1, imagem 2 %32
    • Using the Phillips #2 screwdriver, remove ten 12 mm long screws on the bottom of the device.
  2. GBC Creative Laminator Gear Replacement: passo 2, imagem 1 %32
    • Open the top of the device, and the inside of the Laminator will be exposed as shown.
  3. GBC Creative Laminator Gear Replacement: passo 3, imagem 1 %32 GBC Creative Laminator Gear Replacement: passo 3, imagem 2 %32 GBC Creative Laminator Gear Replacement: passo 3, imagem 3 %32
    • Using the Phillips #2 screwdriver, remove the two 9 mm long screws on the side of the main component that fix the motor in place.
    • Pull the motor off of the main internal component to reveal the gear.
  4. GBC Creative Laminator Gear Replacement: passo 4, imagem 1 %32
    • Pull the gear off of the motor.
Conclusão
4 outras pessoas executaram este guia.
Yujia Tang
Membro desde: 07/11/18
384 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G1, Wilson Summer 2018 Membro de IUPUI, Team S1-G1, Wilson Summer 2018
IUPUI-WILSON-SU18S1G1
Membros da 5
Autoria de 4 guias
Um comentário
Can you tell me where I might find a replacement gear for my GBC H200? I would like to find a brass gear but mine melted and need to find a replacement but no info for the gear. I think it is 17 teeth but not sure about the rest.
Jim Pruitt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 80
Duração total: 3,526
