Ir para o conteúdo principal
GATEWAY NE56R09u RAM Replacement
O que você precisa
  1. GATEWAY NE56R09u RAM Replacement, Battery: passo 1, imagem 1 %32
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u RAM Replacement: passo 2, imagem 1 %32
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u RAM Replacement: passo 3, imagem 1 %32
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
  4. GATEWAY NE56R09u RAM Replacement, RAM: passo 4, imagem 1 %32
    • Locate the casing that protects the RAM modules, wireless card, and hard drive.
  5. GATEWAY NE56R09u RAM Replacement: passo 5, imagem 1 %32
    • With the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the RAM modules.
  6. GATEWAY NE56R09u RAM Replacement: passo 6, imagem 1 %32
    • On each RAM module there are two silver latches holding them in place
    • Release the latches to be able to remove the RAM module.
  7. GATEWAY NE56R09u RAM Replacement: passo 7, imagem 1 %32
    • Remove the RAM modules from their respected slots.
Conclusão
To reassemble your device, please follow these instructions in reverse order.
joshua depina
Membro desde: 03/25/19
401 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S6-G1, Peak Spring 2019 Membro de UMass Dartmouth, Team S6-G1, Peak Spring 2019
UMASSD-PEAK-S19S6G1
Membros da 2
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 237
