Ir para o conteúdo principal
GATEWAY NE56R09u Battery Replacement
O que você precisa
  1. GATEWAY NE56R09u Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u Battery Replacement: passo 2, imagem 1 %32
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u Battery Replacement: passo 3, imagem 1 %32
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
Conclusão
To insert the new battery, follow these instructions in reverse order.
joshua depina
Membro desde: 03/25/19
401 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S6-G1, Peak Spring 2019 Membro de UMass Dartmouth, Team S6-G1, Peak Spring 2019
UMASSD-PEAK-S19S6G1
Membros da 2
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 187
