Ir para o conteúdo principal
GATEWAY ML6720 Disc Drive Replacement
O que você precisa
  1. GATEWAY ML6720 Disc Drive Replacement, Disc Drive: passo 1, imagem 1 %32
    • Remove the six screws with the Phillips #0 Screwdriver that secures the middle large piece of the back panel.
  2. GATEWAY ML6720 Disc Drive Replacement: passo 2, imagem 1 %32 GATEWAY ML6720 Disc Drive Replacement: passo 2, imagem 2 %32
    • Check to see if your laptop requires a screw(s) to be removed for the disc drive. Remove the screw (s) holding the disc drive down.
  3. GATEWAY ML6720 Disc Drive Replacement: passo 3, imagem 1 %32 GATEWAY ML6720 Disc Drive Replacement: passo 3, imagem 2 %32
    • With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
Conclusão
Semirah Dolan
Membro desde: 10/31/16
113 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-3, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G3
2 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Ao todo: 311
