Ir para o conteúdo principal
G-Wolves Hati Paracord Replacement
O que você precisa
  1. G-Wolves Hati Paracord Replacement, Mouse Paracord: passo 1, imagem 1 %32
    • Flip your mouse upside down.
  2. G-Wolves Hati Paracord Replacement: passo 2, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 2, imagem 2 %32 G-Wolves Hati Paracord Replacement: passo 2, imagem 3 %32
    • Peel off the back right mouse skate.
    • Peel slowly, you don't want to create bends on your skate.
  3. G-Wolves Hati Paracord Replacement: passo 3, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 3, imagem 2 %32 G-Wolves Hati Paracord Replacement: passo 3, imagem 3 %32
    • Peel off the back left mouse skate.
  4. G-Wolves Hati Paracord Replacement: passo 4, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 4, imagem 2 %32 G-Wolves Hati Paracord Replacement: passo 4, imagem 3 %32
    • Unscrew both of the uncovered screws.
    • 6.4mm Phillips-head screws.
  5. G-Wolves Hati Paracord Replacement: passo 5, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 5, imagem 2 %32
    • Squeeze the mouse under second mouse button until the bottom opens.
  6. G-Wolves Hati Paracord Replacement: passo 6, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 6, imagem 2 %32
    • Pull the bottom piece towards the back of the mouse and upwards to remove it.
    • Pull carefully there is a ribbon cable still connected.
  7. G-Wolves Hati Paracord Replacement: passo 7, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 7, imagem 2 %32
    • Remove the ribbon cable connecting the bottom piece to the upper piece.
  8. G-Wolves Hati Paracord Replacement: passo 8, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 8, imagem 2 %32
    • Unscrew the following screws:
    • 4.8 mm Phillips-head screws.
  9. G-Wolves Hati Paracord Replacement: passo 9, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 9, imagem 2 %32
    • Flip the bottom piece upside down.
    • Pull the circuit board off without pulling on the cable.
  10. G-Wolves Hati Paracord Replacement: passo 10, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 10, imagem 2 %32 G-Wolves Hati Paracord Replacement: passo 10, imagem 3 %32
    • Grab the side ridges and remove the connection.
    • Do not wiggle till slightly removed to not bend pins.
  11. G-Wolves Hati Paracord Replacement: passo 11, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 11, imagem 2 %32
    • Pop off the paracord from the bottom piece.
  12. G-Wolves Hati Paracord Replacement: passo 12, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 12, imagem 2 %32
    • Press in the new paracord.
  13. G-Wolves Hati Paracord Replacement: passo 13, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 13, imagem 2 %32 G-Wolves Hati Paracord Replacement: passo 13, imagem 3 %32
    • Rearrange wires to follow the guide ridges.
  14. G-Wolves Hati Paracord Replacement: passo 14, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 14, imagem 2 %32
    • Re-insert the circuit board by lining up the scroll wheel with the front piece and pressing down.
  15. G-Wolves Hati Paracord Replacement: passo 15, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 15, imagem 2 %32
    • Re-insert the screws.
  16. G-Wolves Hati Paracord Replacement: passo 16, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 16, imagem 2 %32
    • Thread the wire through the side opening.
    • Insert the paracord connection.
  17. G-Wolves Hati Paracord Replacement: passo 17, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 17, imagem 2 %32
    • Insert the ribbon cable.
    • Cable is located on the upper mouse piece.
  18. G-Wolves Hati Paracord Replacement: passo 18, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 18, imagem 2 %32 G-Wolves Hati Paracord Replacement: passo 18, imagem 3 %32
    • Hover the bottom piece over the upper piece flipped over.
    • Press the bottom piece down and forward till under clip pieces.
    • Press down where skates where removed till there is a click.
  19. G-Wolves Hati Paracord Replacement: passo 19, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 19, imagem 2 %32
    • Insert the screws.
    • 6.4mm Phillips Head Screws.
  20. G-Wolves Hati Paracord Replacement: passo 20, imagem 1 %32 G-Wolves Hati Paracord Replacement: passo 20, imagem 2 %32 G-Wolves Hati Paracord Replacement: passo 20, imagem 3 %32
    • Press on the skates.
Linha de Chegada
Ayaan
Membro desde: 10/23/23
301 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Duração total: 246
