O que você precisa
There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
Remove one screw located on the left side of the phone with the pictured orientation in mind.
This will release the logic board from the back case.
Lift the board out of the case starting with the top. Continue to fold it forwards to access the ribbon cable still connecting it.
Lift speaker towards yourself out of the white plastic container.
Gently unplug the ribbon by pulling it to the left with the pictured orientation in mind.
