Ir para o conteúdo principal
Furnace Humidifier Evaporator Pad Replacement
O que você precisa
  1. Furnace Humidifier Evaporator Pad Replacement, Furnace Humidifier Evaporator Pad: passo 1, imagem 1 %32
    • Turn off the humidifier. (Set the humidistat to 0% humidity)
  2. Furnace Humidifier Evaporator Pad Replacement: passo 2, imagem 1 %32 Furnace Humidifier Evaporator Pad Replacement: passo 2, imagem 2 %32
    • Remove the nuts and clips holding the top cover of the cabinet assembly to the bottom cabinet housing.
  3. Furnace Humidifier Evaporator Pad Replacement: passo 3, imagem 1 %32
    • Remove the side clips or fasteners.
  4. Furnace Humidifier Evaporator Pad Replacement: passo 4, imagem 1 %32
    • Use an adjustable wrench to loosen the nut which holds the water distributor tube and swing the tube out of its secured place.
  5. Furnace Humidifier Evaporator Pad Replacement: passo 5, imagem 1 %32
    • Remove the top of the bottom cabinet housing and take out the evaporator pad.
  6. Furnace Humidifier Evaporator Pad Replacement: passo 6, imagem 1 %32 Furnace Humidifier Evaporator Pad Replacement: passo 6, imagem 2 %32
    • Place the new evaporator pad inside the clean bottom cabinet.
    • The sides should guide it into the correct position.
  7. Furnace Humidifier Evaporator Pad Replacement: passo 7, imagem 1 %32
    • Replace the clips, nuts, and bolts removed in steps 2 through 4.
  8. Furnace Humidifier Evaporator Pad Replacement: passo 8, imagem 1 %32
    • Turn on the humidifier.
Conclusão
Enjoy your warm air! Your repair is complete!
Zia Ahmed
Membro desde: 07/11/21
190 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 28
Ao todo: 683
