Introdução
This guide will show Furbo Dog Camera users how to effectively remove the various components of the treat tossing chamber. By removing the chamber, you will be able to remove any dislodged treats or replace the treat chamber components altogether. Be sure to carefully keep track of all screws and pieces along the way!
O que você precisa
Ferramenta utilizada nesse passo:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
Use a Phillips #000 screwdriver to remove the two small 3 mm black screws on either side of the plastic hinge.
After removing the two screws, carefully pull off the plastic hinge.
