Introdução
This guide will show you how to remove the rear housing and begin disassembly of your Furbo Dog Camera (Model:Furbo2). Removing the outer housing allows you to access the inside of your Furbo and fix and replace any parts if necessary. Sometimes separation of the plastic components may be difficult, so be careful not to break your Furbo.
O que você precisa
Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
