Ir para o conteúdo principal
Fujtsu Lifebook Model A6110 Battery Replacement
  1. Fujtsu Lifebook Model A6110 Battery Replacement, Battery: passo 1, imagem 1 %32 Fujtsu Lifebook Model A6110 Battery Replacement, Battery: passo 1, imagem 2 %32
    • The computer should be fully turned off and disconnected from the power source.
    • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
    • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
  2. Fujtsu Lifebook Model A6110 Battery Replacement: passo 2, imagem 1 %32
    • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
Conclusão
Alvin Thamrin
Membro desde: 10/25/16
132 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 3-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 449
