Ir para o conteúdo principal
Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement
O que você precisa
  1. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn the laptop over so that the bottom of the laptop faces you.
  2. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 2, imagem 1 %32 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 2, imagem 2 %32
    • Locate the hard drive cover and remove the screw.
  3. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 3, imagem 1 %32 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 3, imagem 2 %32
    • Now you can use your finger to pull the cover off.
  4. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 4, imagem 1 %32 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 4, imagem 2 %32 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 4, imagem 3 %32
    • Pull on the pull tab to release the hard drive.
    • Now you can take the hard drive out of the laptop.
  5. Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 5, imagem 1 %32 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 5, imagem 2 %32 Fujitsu Siemens Esprimo Mobile v5515 Hard Drive Replacement: passo 5, imagem 3 %32
    • There is a screw on each corner of the hard drive bracket. To take the hard drive out of its bracket you need to remove the 4 screws.
    • Do not take the screws out of the hard drive itself, only from the bracket.
    • With the screws removed the drive slides out of the bracket.
    • Now you can replace the hard drive with a new one.
Conclusão
5 outras pessoas executaram este guia.
storm
Membro desde: 07/07/12
552 Reputação
Autoria de 2 guias
2 comentários
Please I need a password protection my computer is locked I need a code to unlock my computer pls Esprimo mobile V5515 please help me
sadik G Ibrahim - Responder
Is it a Windows password or a BIOS password?
storm -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 5,979
