Pular para o conteúdo principal
Introdução
A repair manual for the Fujitsu Siemens Amilo Pro 2010 and 2020 and 2030 which shows you how to replace the keyboard!
  1. Remove AC adapter and battery.
    • Remove AC adapter and battery.
    • Battery: pull the latch with a battery symbol beside it.
  2. Use a flat head screwdriver to pry out the hinge cover.
    • Use a flat head screwdriver to pry out the hinge cover.
    • (Caution do not pull to hard as this could snap the plastic!)
  3. Remove the one screw holding in the keyboard.
    • Remove the one screw holding in the keyboard.
  4. Pull the keyboard up towards you.
    • Pull the keyboard up towards you.
  5. Pull the ribbon cable and the keyboard will come out.
    • Pull the ribbon cable and the keyboard will come out.
    • (Caution this ribbon is very delicate)
Conclusão
Uma outra pessoa concluiu este guia.
Jeremy Scalpello
Membro desde: 25-04-2010
298 reputação
Autoria de 1 guia
try to focus the image while taking the picture so people can understand better were to touch
storm builder - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 48
Todo: 14,481
