Ir para o conteúdo principal
Fujitsu Lifebook Stylistic Q584 USB port Replacement
O que você precisa
  1. Fujitsu Lifebook Stylistic Q584 USB port Replacement, Back Case: passo 1, imagem 1 %32
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 USB port Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 USB port Replacement: passo 3, imagem 1 %32
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 USB port Replacement, Inner Back Shield: passo 4, imagem 1 %32
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 USB port Replacement: passo 5, imagem 1 %32
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 USB port Replacement: passo 6, imagem 1 %32
  7. Fujitsu Lifebook Stylistic Q584 USB port Replacement: passo 7, imagem 1 %32
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 USB port Replacement, USB port: passo 8, imagem 1 %32
    • Remove 2mm screw with a PH1 screwdriver from USB board
  9. Fujitsu Lifebook Stylistic Q584 USB port Replacement: passo 9, imagem 1 %32
    • Disconnect USB periphery ribbon from motherboard
  10. Fujitsu Lifebook Stylistic Q584 USB port Replacement: passo 10, imagem 1 %32
    • Pull USB board up to remove.
Conclusão
Spencer Bacon
Membro desde: 09/21/17
410 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 473
