Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
If your speakers are damaged or not working this guide will show you step-by-step instructions on how to replace your speakers
  1. Remove the white sticker covering the screws (if applicable).
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Insert the plastic opening tool along the seam of the back case.
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Carefully lift the back case and remove the smartcard ribbon from the motherboard.
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Remove the ten 3mm screws with a  PH00 screwdriver from the shield.
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Remove the grey docking station port cover.
    • Remove the grey docking station port cover.
  6. Gently slide the plastic opening tool along the entire seam popping the clips free.
  7. Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Pull up the cord that connects the battery to the motherboard
    • Pull up the cord that connects the battery to the motherboard
  9. Use the narrow plastic opening tool to pry the speakers from the casing. Use the narrow plastic opening tool to pry the speakers from the casing.
    • Use the narrow plastic opening tool to pry the speakers from the casing.
  10. Unplug the speaker wires from the motherboard.
    • Unplug the speaker wires from the motherboard.
Conclusão
Connor Stanton
Membro desde: 21/09/2017
601 Reputação
6 Guias de autoria
Equipe
Hello,
Thanks for this guide.
Is the ssd storage card replaceable on the q584.
I want to put a 256gb card internally.
Also, I notice a slot where the 4G /LTE modem goes.
Do you know the part number of that addition.
Thanks
Vince - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 262
