Ir para o conteúdo principal
Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement
O que você precisa
  1. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Back Case: passo 1, imagem 1 %32
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 3, imagem 1 %32
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Inner Back Shield: passo 4, imagem 1 %32
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 5, imagem 1 %32
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 6, imagem 1 %32
  7. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 7, imagem 1 %32
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Battery: passo 8, imagem 1 %32
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 9, imagem 1 %32
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 10, imagem 1 %32
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 11, imagem 1 %32
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, Motherboard: passo 12, imagem 1 %32
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 13, imagem 1 %32
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 14, imagem 1 %32
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 15, imagem 1 %32
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 16, imagem 1 %32 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 16, imagem 2 %32 Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 16, imagem 3 %32
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement: passo 17, imagem 1 %32
    • Remove the connector with an ESD-safe spudger.
  18. Fujitsu Lifebook Stylistic Q584 MicroSD Card Replacement, MicroSD Card: passo 18, imagem 1 %32
    • After removing the motherboard, use an ESD-safe spudger to pry up the MicroSD card from the slot.
    • Gently separate the MicroSD card from the device.
Conclusão
Casey
Membro desde: 03/25/19
280 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G1, Henning Spring 2019 Membro de IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
Membros da 3
Autoria de 3 guias
Um comentário
I have some OS problem can the SSD be replaced..?
Faiz Rahmathulla - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 477
