Introdução
This is another protective layer you will need to remove prior to accessing the internal parts of the device.
O que você precisa
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Quase terminado!
Conclusão
