Ir para o conteúdo principal
Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement
O que você precisa
  1. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Back Case: passo 1, imagem 1 %32
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 3, imagem 1 %32
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Inner Back Shield: passo 4, imagem 1 %32
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 5, imagem 1 %32
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 6, imagem 1 %32
  7. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 7, imagem 1 %32
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Battery: passo 8, imagem 1 %32
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 9, imagem 1 %32
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 10, imagem 1 %32
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 11, imagem 1 %32
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement, Headphone Jack: passo 12, imagem 1 %32
    • Remove the two 0.2 mm screws with a PH00 Screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 13, imagem 1 %32
    • Remove the two 0.2 mm screws with a PH00 screwdriver
  14. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 14, imagem 1 %32
    • Now use an ESD-safe spudger to gently pry up the silver piece and flip it over. Be sure not to remove this piece completely!
  15. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 15, imagem 1 %32 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 15, imagem 2 %32
    • Use an ESD-safe spudger to gently push the yellow piece out from the white cradle.
  16. Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 16, imagem 1 %32 Fujitsu Lifebook Stylistic Q584 Headphone Jack Replacement: passo 16, imagem 2 %32
    • When removing the headphone jack, simply use your fingers to pull out the white and black piece altogether.
Conclusão
Briana Cockerham
Membro desde: 03/26/19
130 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Henning Spring 2019 Membro de IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 440
