Ir para o conteúdo principal
Fujitsu Lifebook Stylistic Q584 Camera Replacement
O que você precisa
  1. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Back Case: passo 1, imagem 1 %32
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 3, imagem 1 %32
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Inner Back Shield: passo 4, imagem 1 %32
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 5, imagem 1 %32
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 6, imagem 1 %32
  7. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 7, imagem 1 %32
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: passo 8, imagem 1 %32 Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: passo 8, imagem 2 %32
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 9, imagem 1 %32 Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 9, imagem 2 %32
    • Pull the ribbon straight up from the back of the camera board
  10. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 10, imagem 1 %32
    • Remove the single 2mm screw using a PH000 screwdriver from the camera board.
Conclusão
Connor Stanton
Membro desde: 09/21/17
613 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 289
