Ir para o conteúdo principal
Fujitsu Lifebook S6120 Hinge Cover Replacement
O que você precisa
  1. Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: passo 1, imagem 1 %32 Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: passo 1, imagem 2 %32 Fujitsu Lifebook S6120 Hinge Cover Replacement, Battery: passo 1, imagem 3 %32
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Hinge Cover Replacement, Hinge Cover: passo 2, imagem 1 %32 Fujitsu Lifebook S6120 Hinge Cover Replacement, Hinge Cover: passo 2, imagem 2 %32
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Hinge Cover Replacement: passo 3, imagem 1 %32
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Hinge Cover Replacement: passo 4, imagem 1 %32 Fujitsu Lifebook S6120 Hinge Cover Replacement: passo 4, imagem 2 %32 Fujitsu Lifebook S6120 Hinge Cover Replacement: passo 4, imagem 3 %32
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Hinge Cover Replacement: passo 5, imagem 1 %32 Fujitsu Lifebook S6120 Hinge Cover Replacement: passo 5, imagem 2 %32 Fujitsu Lifebook S6120 Hinge Cover Replacement: passo 5, imagem 3 %32
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
Conclusão
Jaimie Nakamura
Membro desde: 03/20/18
229 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S5-G5, Peak Spring 2018 Membro de UMass Dartmouth, Team S5-G5, Peak Spring 2018
UMASSD-PEAK-S18S5G5
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 347
