Ir para o conteúdo principal
Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement
O que você precisa
  1. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two clips on the bottom of the computer that support the battery.
  2. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 2, imagem 1 %32
    • Using your fingers, push the clips inward and then upward.
    • Lift the battery out of the computer.
  3. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: passo 3, imagem 1 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: passo 3, imagem 2 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Hinge Cover: passo 3, imagem 3 %32
    • Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
  4. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 4, imagem 1 %32
    • Lay the computer flat on a stable surface with the monitor pointing away from you.
  5. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 5, imagem 1 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 5, imagem 2 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 5, imagem 3 %32
    • Use a spudger to partially lift the hinge cover.
  6. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 6, imagem 1 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 6, imagem 2 %32
    • The hinge cover has a ribbon cable that is attached to the motherboard. To prevent damage, lift the hinge cover slowly.
    • Lift the hinge cover enough to expose the ribbon cable.
  7. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 7, imagem 1 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 7, imagem 2 %32
    • Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
  8. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: passo 8, imagem 1 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: passo 8, imagem 2 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Keyboard: passo 8, imagem 3 %32
    • The keyboard has a ribbon cable that is attached to the motherboard. To prevent damage, lift keyboard slowly.
    • Lift the keyboard enough to expose the ribbon cable.
  9. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 9, imagem 1 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 9, imagem 2 %32
    • Use a spudger to release the ribbon cable from the motherboard.
  10. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 10, imagem 1 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 10, imagem 2 %32
    • After the ribbon has been detached, carefully remove the keyboard.
  11. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement, Metal Motherboard Cover: passo 11, imagem 1 %32
    • Remove the following screws, all labeled "3."
    • Two 8.63mm screws.
    • One 7.65mm screw.
    • One 5.74mm screw.
    • Remove the following screw, labeled "15."
    • One 17.81mm screw.
  12. Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 12, imagem 1 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 12, imagem 2 %32 Fujitsu LifeBook N3510 Metal Motherboard Cover Replacement: passo 12, imagem 3 %32
    • Lift the cover with fingers and remove.
Conclusão
Neil Daniels
Membro desde: 01/17/11
1.411 Reputação
11 Guias de autoria
Equipe
Cal Poly, Team 5-18, Amido Winter 2011 Membro de Cal Poly, Team 5-18, Amido Winter 2011
CPSU-AMIDO-W11S5G18
3 Membros
22 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 3,578
